- Ron3rdExplorer III
westend wrote:
Ron3rd wrote:
Here you can see the video:Eternabond video. I actually used Eternabond Webseal and it performed just like the video depicts, covering the screw head and filling the hole as I turned the fastener, amazing stuff!westend wrote:
If you use Eternabond Double-Stick tape over each hole, while you are fastening, the tape will seal each screw hole.
That's a very good idea. I've used EB before but did not think of using it in that way.
Nice info westend. Thanks for passing that along. - MrWizardModerator
GENECOP wrote:
3m double sided tape, research it, it's not tape the way you know it...
great for fiberglass or Alu
i would not do that to a rubber roof
many rubber roofs get bubbles
bubbles won't hurt a bare roof
but a bubble under the panel or under the mounting feet would mean
no mount, just a loos foot vibrating bouncing with the rubber, while going down the road
screw the feet down, use the right sealant on them
i screwed eleven panels to my rubber roof - westendExplorer
That's a very good idea. I've used EB before but did not think of using it in that way. - Ron3rdExplorer IIILike noted above, we all have dozens of holes on our roof already from things like vents, air conditioners, ladders, etc. Sealed properly, a few more screw holes won't hurt anything.
- paddywanpeepExplorer
I used Instapark® ZJ-34W Universal Drill-free Solar Panel Rooftop Mount and Sikaflex 252
No holes in the roof.
When I bought the Instapark - it was $35. It has gone up in price
I have never seen anything like that before and it looks pretty cool - rkentzelExplorerAfter you drill the first hole you throw up and the rest go easy.
- portscannerExplorerI used Instapark® ZJ-34W Universal Drill-free Solar Panel Rooftop Mount and Sikaflex 252
When I bought the Instapark - it was $35. It has gone up in price - Ron3rdExplorer III
That's a very good idea. I've used EB before but did not think of using it in that way. - westendExplorerIf you use Eternabond Double-Stick tape over each hole, while you are fastening, the tape will seal each screw hole.
- jmanateeExplorer
2oldman wrote:
I'll be the first to say holes in the roof is no biggie. Punched 48 of them for my panels. With proper sealant you're fine.
ditto
I the previous coach, I had 48 holes too. Used Butyl tape under brackets and Dicor over bolts and around edge of bracket.
Never leaked a drop
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,397 PostsLatest Activity: Dec 04, 2025
