memtb's avatar
memtb
Solar Panels- Another Step Toward Independence
This should’ve been done a year ago.....but, life continually gets in the way! I’ve got to purchase some wire, junction boxes to finish the tie-in.
Installed these this morning on our Class C. The photo shows that the panels ( 4 x 100 watts) can be adjusted to take full advantage of the seasons/sun angle! memtb
  • Tvov's avatar
    Tvov
    Explorer II
    I would think having to tilt the panels would depend on daily usage? Most days you should be fine with the flat panels? The tilt ability is there, if you need it.
    Oh, and by the way... what a clean roof!
  • memtb,
    I don't known if they are available in the format you want.
  • FWV, yes a very small strip of the panel is covered! memtb
  • Agreed on the tilting panels, unless you are planning on staying in one location for a long time, it is unlikely that you will end up tilting them. Easier to add more panels than dealing with tilting.
    On closer inspection, are your mounting brackets covering some of your solar cells? If so this can have a surprisingly large impact - reducing the current from ALL the cells in that string. It may be worth getting some narrower extrusions.
  • Yep, not much fun to spend time on the roof....especially with several inches of snow. We had tilt panels on our 5ers for years, and the older I get the harder it is.....I’ll have to look into actuators. The panels would only angled when we would be spending 2 to 3 or more days in one location, spring, fall or winter....but, that’s when we do the majority of our camping.
    Pianotuna, can the actuators be had, to lift in two directions ,left or right?
    jdc1, Thanks for the roof warning, however, we have a pretty heavy duty, well constructed unit! Zero to near zero flex when walking on the roof! memtb
  • jdc1's avatar
    jdc1
    Explorer II
    And those roofs are not made to continuously walk on.
  • Nice installation. :C
    I agree, manually raising the panels would get old in a hurry.
  • Hi memtb,
    Consider using actuators for tilting. I can't imagine going up on the roof when it is raining and windy to strike the panels.
  • You’ll enjoy solar but tire of titling panels. Looks like a quality installation. Use adequately sized wire as determined by a good chart.
    I use WindyNation’s at: https://www.windynation.com/jzv/inf/choosing-right-wire-size
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,387 PostsLatest Activity: Aug 18, 2025
