nvreloader's avatar
nvreloader
solar tilting
BFLK 13
Since you like to think outside the box, so to speak, :B
here is something I found that might interest you,
see info here:
http://www.ebay.com/itm/Universal-two-way-adjustable-heavy-duty-solar-panel-pole-mount-pan-tilt-/262722824155?
Tia,
Don
  • Interesting device!
    I'm thinking right now of how I want to establish a ground array at Casa Westend. This would be about 15-20 modules and they should have adjustable tilt for seasonal differences in sun angle. Up here, at 45 latitude, we get a short day in Winter so getting the best harvest is critical.
    FWIW, I installed a four way tilt for the single module on my TT roof. If I had to do it over, it would only tilt one or two ways as getting up there to adjust different tilt angle is troublesome. In storage, I set the tilt to about 60 degrees and it sits like that all Winter. When travelling the module lies flat.
    I am considering adding another module or two and adding battery capacity. This would enable me to run a small 5K air conditioner for a few hours, when needed. An alternative, while on trips, is to just pull in a camp ground and use the available power. I just would rather park away from folks, my personal preference but not always possible.
  • Just hope the wind doesn't come up with the panel tilted on that bracket.
  • Old Days wrote:
    That is a bracket from a satellite dish. I have 2 of them in my garage.
    Someone finally figured out what to do with all those unused brackets. :)
  • That is a bracket from a satellite dish. I have 2 of them in my garage.
  • Mr Wizard
    Thank you for that,
    I haven't learned that trick yet. :(
    This solar stuff has me :@ right now.
    Tia,
    Don
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
