Harvey51
Sep 22, 2016Explorer
Ah, that could be useful for sure. I guess you would record a series of voltages as a battery is under load, graph it. Then do it again in a month or year and see if there is a change.
I tried to find a graph of voltage vs time on a resting battery but haven't found one. I know, I should do it myself with my batteries.
I did find this comment at battery university:
Battery university
http wrote:
Voltage Method
Measuring state-of-charge by voltage is simple, but it can be inaccurate because cell materials and temperature affect the voltage. The most blatant error of the voltage-based SoC occurs when disturbing a battery with a charge or discharge. The resulting agitation distorts the voltage and it no longer represents a correct SoC reference. To get accurate readings, the battery needs to rest in the open circuit state for at least four hours; battery manufacturers recommend 24 hours for lead acid. This makes the voltage-based SoC method impractical for a battery in active duty.
Battery university
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
