sjturbo wrote:
I was aware that grid means the household electric grid but I did not know that there was any difference in the panel itself. Can you tell me what the actual difference? Also I am not aware of panels that can be shaded and not have their performance degraded. Anyone?
As others said, amorphous panels work better in low light or partial shade. The drawback is that they are waay less efficient per sq.ft, like Full Mosey said "require more real estate". So unless you always camp in the shade, I don't think it's worth it.
Crystalline panels are more efficient per sq ft, and mostly you will see this type in solar stores. They can be poly- and monocrystalline. Poly is said to be "somewhat" more efficient in low-light, but I don't think this should be the deciding factor.
"Low light" in case of crystalline panels should not be confused with "partial shade" - the latter is when part of the panel is shaded and the rest is in bright sun, and this is where the layout of the panel is important. I haven't heard of panels distinguished by "grid" and "non-grid". Usually people describe the panel by its nominal voltage (i.e. 12V or 24V), and cells layout i.e. a number of strings of cells and number of diodes between them.
In more details on myth of "considerably" or "completely" degraded production of panels in partial shade. Again, we should distinguish between multi-panel array when some panels are in partial shade, and a single panel when part of this panel is in shade.
Single panel: the higher is the number of diodes, the better it handles partial shade. 2 is considered "not good enough", 4 and more is considered "enough". Though manufacturers, especially no-name Chinese panels that have flooded the market, rarely tell the number of diodes. So I suggest you forget about this. Any panel will generate less power when partially shaded or in low light.
Muti-panel array: let's say one panel in array dropped out of production because it has only few diodes OR because it's almost entirely in the shade. Doesn't matter why - the panel is out or almost out.
A) If your array is made of panels wired to each other
in parallel, you will only lose production of this one panel. So if you have 6 panels and one is down to 30% of production, you lose 1/6 of 0.7, or 11% of total production. This peanuts, nothing.
B) If your array is made of panels wired
in series, and one has dropped to 0.3 of its capacity, then all other panels will also drop to 0.3 of their capacity, so you lose 70% of total production. Not always, but for simplicity this is how you should think of it. Imagine a series of pipes where one is partially blocked to 0.3 - the entire pipeline capacity drops to 0.3 of initial.
I hope this wasn't too "technical". In case if it was, just remember that when you have many panels with frequent shading on some panels, it's better to wire them in parallel. Not absolutely necessary, but better.
Another thing to remember is that you can never have "too much" solar. Get as much total panel wattage as possible. When you have a lot of total wattage, you may forget about "pitching" (called, btw, tilting). You can increase production by 30-50% by tilting, and you can increase it by adding more panels.
There was a good suggestion to make "dummies" out of cardboard and see how they fit. After you've figured out how many panels and of what wattage you will have, people will tell you what controller you should get. You will find panels dimensions in places like
http://www.solarblvd.com. Note that there are 12V nominal and 24V nominal panels - I think for installs 500W and larger, 24V panels would work better, and your 5-er allows at least that much. With flat array (= not tilted), size 600W or larger, in AZ you should be able to live off solar without ever needing a generator, other than when you need airconditioner. A/C is the only thing that solar can't handle. Some people can live off 300-400W in places like this. Depends on whether you're trying to conserve energy or not.
And, - no, this is not the forum where people usually discuss solar. I don't think this is something curved in stone, it's just the way people here got used to it.
