- Ron3rdExplorer III
Old-Biscuit wrote:
Your part number is not long enough.......3853111....it's missing 2 numbers and the only numbers that match up to that sequence is 64 (385311164----seal, grommet for the vacuum breaker).
Dometic/SeaLand......same same
Sprayer is an option.....part number for kit is 385319054 which is the correct kit in your CW link. Sprayer, vacuum breaker, seal, hose brace/clamp & wall bracket.
You're right OB, I dropped 2 digits off the cut and paste. The correct number on the Dometic parts list is 385311124 which pops up everywhere on a google search. I'll go with that kit. Thanks for the info.
ON EDIT,
It looks like they offer 2 kits, one with the vacuum breaker (385319054) and the one without: 385311124. I can't see the back well without pulling the seat off and I'll do that in the morning. It looks like the vacuum breaker is already there.
Here's a link to the parts list so you can see what I'm talking about:
310 Parts List - Old-BiscuitExplorer IIIYour part number is not long enough.......3853111....it's missing 2 numbers and the only numbers that match up to that sequence is 64 (385311164----seal, grommet for the vacuum breaker).
Sprayer is an option.....part number for kit is 385319054 which is the correct kit in your CW link. Sprayer, vacuum breaker, seal, hose brace/clamp & wall bracket. - Ron3rdExplorer III
old guy wrote:
I thought the 310 came with a sprayer, mine did
Thanks for the info folks, my 310 on my new Windjammer did not come with the sprayer for some reason. I'm confused what to order; the Dometic parts list for the 310 shows the kit optional under part number 3853111 (Dometic Spray Kit), but if you google that number, nothing comes up. If you google Dometic Hand Sprayer, you get this from CW:
so I'm wondering if that's the right kit as that model is also listed for a Sealand marine toilet. - old_guyExplorerI thought the 310 came with a sprayer, mine did
- Old-BiscuitExplorer IIIIf you look on bottom of vacuum breaker next to where hose from water valve attaches there should be a 'stub'. That is where the spray hose attaches....after you open the stub.
Have a sprayer on my Thetford and love it......helps keep bowl, seal, ball cleaner with just a quick spray around the bowl after a dump.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,386 PostsLatest Activity: Aug 14, 2025
