cs2kplus's avatar
cs2kplus
Spring Over Axle Conversion
Greetings again.
I have posted about flipping axles. Which I have learned it is know as "spring axle conversion".
I have an old 89 trailer. Fleetwood Taurus. It is low and I have issues getting in and out of my driveway.
I asked an RV repair place what it would cost. One said $400 to remove axle (unclear if that one or 2 - 2 is what I have). Then the cost of replacement parts.
Another said $1000 for the job.
I am not sure what a good price range should be?
I think I agree that the actual change in height will be 4". That works for me.
I have some questions:
Its interesting how this axle (3") slings down. Will this be an issue - as opposed to a centered axle?
Here is a shot that I suspect the perch is not actually welded? Does not look like pics I've seen online.
Here is another view of the stackup
Any thoughts on all of this info?
Thanks,
Wayne
  • Yes...I know its a sight to behold. But everything functions currently. I do believe that it is all surface rust. It is an 89. It was used as a fire department demo for fire safety and don't think it has actually seen many travel miles. I drove to and from NJ to Indiana with no issues.
  • Those are drop axles and really junky looking. You'd be big money ahead to just buy new springs, axles and brake assemblies. Not sure you could even re-use most of that. Those springs are so rusted and corroded that I bet they hardy work.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jan 18, 2025
