TakingThe5th
Mar 09, 2014Explorer
OP-when you mentioned double-sided tape it brought to mind some hooks my DW uses all over the FW-they use an adhesive that just doesn't let go, Not sure what it is-you can find these hooks at Home Depot if you want to look into it. When you want to remove the hook you grab a tab and pull it down hard.
Due to the heat in that area, I would suggest putting in just a few screws for some stability.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,405 PostsLatest Activity: Apr 21, 2026
