Fineoceanparker's avatar
May 24, 2014
Suggestions on where to install exterior shower?...
I have a 24' slumber queen 1997. I would love to install a exterior hot/cold shower somewhere just not sure where. Has anyone had experience installing one on a similar rig? Also, what's the best way to cut into the rig? I'm thinking drill a hole and use a jig saw and defiantly a measure twice cut once job. Mostly I am having a hard time locating enough empty space to do the job. Any input is appreciated.
  • Also be aware that dumping grey water on the ground is a no-no
    Jim
  • TucsonJim wrote:
    I think the first consideration would be where could you access the plumbing to make a connection. Funny, I've had one for the last 15 years, and never used it.
    x2
    well I do use mine twice a year. once to winterize, once to de-winterize.
    bumpy
  • Ours is on the outside wall of our bathroom if you open the bathroom cubboard you can see the back side of the outside shower
  • I think the first consideration would be where could you access the plumbing to make a connection. Funny, I've had one for the last 15 years, and never used it.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,390 PostsLatest Activity: Sep 18, 2025
