Hornnumb2's avatar
Hornnumb2
Switch Style Battery Disconnect
Does it matter if I do the negative or positive terminal? Thanks
  • Normally they are installed in the red or positive(+) lead. Electrically there is probably a good reason for this which I suspect is to ensure the power is off.. Otherwise if you had a ground it might not properly kill the power.
    Sure others can give a more precise reason.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,397 PostsLatest Activity: Dec 04, 2025
