- dbatesExplorerI installed my SeeLevel II tank monitor system over nine years ago and although it's not perfect its soooo much better than the OEM system that came with the MH. Occasionally the black & gray tank readings get out of line but if I use the GEO method to clean them the gauges work fine again.
Dave - jjrbusExplorerMore years ago than I care to remember I built a motorhome. The external sensors were new on the market and expensive, but nothing but the best for my coach!
After a couple years the monitor failed, a new one was as much as a whole system and they had changed the design of the panel so it would not fit in the original space.
An old timer told me to check the black tank by shinning a flashlight down the toilet and the fresh tank by holding a flash light up to the tank.
Not for everyone, but worked very well for me. Jim - DelphiExplorerI installed the SeeLevel II gauges last summer and we love them. They're much more accurate than the standard sensors.
It was a bit of a project to retrofit the SeeLevel display panel into my range hood, but it turned out fine. - 12thgenusaExplorer
Trackrig wrote:
Hornnumb2 wrote:
Trackrig wrote:
I had the SeeLevel gauge installed and am not pleased with it. I wouldn't do it again. Just learn to understand what your gauges are telling you.
Bill
What is it that you are not liking?
I don't really think they're any more accurate than the original gauges and the voltage gauge doesn't read right. Even when filling the drinking water tank (which won't have anything floating around the tank) they're not very accurate. While filling, nothing will happen on the gauge and then all of a sudden the reading takes a large leap.
I think I would just pull it all out, but when they installed it, they had to enlarge the hole in the gauge cabinet to fit the SeeLevel gauge panel. While I kept my original gauge panel, I'll have to put in a new backing plate to mount it. I now have the MH back up near a shop I like and they'll look at it next spring to see if they can get it to work right.
Bill
Sounds like something wasn't installed correctly. Mine works very smoothly. The readouts change at approximate 6% increments. They will read 100% somewhat before they are completely full and the fresh water will show empty while there are several gallons left. Mine has the integrated water pump switch. When the pump isn't running the voltage readout is within .1v of the Trimetric readout. If the water pump is running, the localized voltage drop will make the voltage readout be several tenths lower.
Overall, if you don't mind paying the price the SeeLevel II is great. Installed mine in 2012 and not a hitch since. - TrackrigExplorer II
Hornnumb2 wrote:
Bill
Bill Hornnumb2 wrote:
What do they do exactly?
My sensors always don't read accurate, what brand is recommended for replacement? Thanks
None are perfect. Mine work pretty good. Only the top 2 positions are important anyway.- dons2346ExplorerHave you tried the Geo Method to clean your tanks and sensors? Try it, you might have to do it a couple of times to clean everything out.
Geo Method - hersheyExplorerThe tank level indicators were designed by an evil mind. You can spend countless amount of time and effort to make them work and if successful they will work once in a row and its back to the cleaning process again. Just figure out how long you can go between your need to dump the gray tank and use the calendar to judge the level. You'll never fill the black before the gray.
- Hornnumb2Explorer
Bill
What is it that you are not liking? - TrackrigExplorer III had the SeeLevel gauge installed and am not pleased with it. I wouldn't do it again. Just learn to understand what your gauges are telling you.
Bill
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
