Hornnumb2's avatar
Hornnumb2
Tank level sensors
My sensors always don't read accurate, what brand is recommended for replacement? Thanks
  • We have been very pleased with our SeeLevel II tank monitor system. The sensors are externally mounted on the tanks, so they're much less susceptible to crud build up. The levels display in percentages, making them more accurate than the empty,1/3,2/3,full systems. The battery display is in actual volts as well. Installation is fairly easy with reasonable tank access, and the existing wiring can be used to connect the sensors to the display. Different panel configurations are available, depending on your needs.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
