Paul_D_
Sep 15, 2014Explorer
I used a moisture resistant Gorilla tape, be aware that the dicor water based adhesive does not dry well over these taped seams. One near a vent I have yet to install is still quite tacky after a week of being in the sun and a dehumidifier set at 50% on the inside. Read somewhere that the tape helps to protect the membrane from screw heads and uneven seams.
The manufacturer used standard grey duct tape and it held up well in areas that did not see excessive moisture. Almost too well on the rear corner.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,408 PostsLatest Activity: May 09, 2026
