Cerevisaphile's avatar
Jan 12, 2014
That darn 12v cable...
I am not sure what i am doing wrong here.... I have a class c thor motorhome... I thought it would be nice to be able to watch TV when we are dry camping and since the RV doesnt come with an inverter and i dont want to make too many modification i thought the easiest solution was this.
Connect a 12 volt outlet to the 12 volt cable in the entertainment cabinett which is hooked up to the house battery.
Connect one of those cupholder inverters and run the tv and roku or media player to it.
Inverter is 200 watts 400 peak...not a pure sine
Tv draws 48 watts and roku/media player 5 watts
This is what happens...
Plug inverter in ..it shows green light..
Plug tv into inverter light flashes green/red...but tv works no issues
Plug roku in inverter flashes red/green and tv goes on and off
Plug in roku only light on inverter stays green
So for me that means the inverter can not handle the load..yet its just 25 % of the listed load.
Any suggestions ? I think i might get another inverter (pure sine)with a higher load that i can connect directly to the house battery and see if that fixes the problem
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,397 PostsLatest Activity: Dec 04, 2025
