pkunk
Dec 02, 2013Explorer
glorio wrote:Thin because they're cheap :R
Look at the plastic plug carefully and you will notice
that the wall of the plug not the threaded part is very
thin. This may be some kind of pressure release should the
pressure relief valve fail. Maybe we should check with the
OEM before we bypass this. Just my thoughts.
I use a brass bushing down to 1/4" and a brass 1/4" ball valve.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,411 PostsLatest Activity: Jun 27, 2026
