JnJnKatiebug's avatar
JnJnKatiebug
The dreaded plastic hot water plug/my fix
I see where people here have problems with their plastic hot water plug. Here is how I fixed mine. I used this for 9 years on my TT and now for 4 years on my MH so it has been well tested, never had a problem.
Went to Lowe's and bought a brass coupler, pipe threads on one end and male water hose on the other. Also bought a metal cap for a water hose. Use a little teflon tape and put the fitting in the HW heater (not too tight) then use the cap as needed. I only hand tighten the cap. Never had a leak and never have a problem getting the cap off, just change the washer every couple of years.
Added benefit is you can put a hose on it so the water does not run down the side of you camper or you can catch it in a bucket and use the hot water if needed.
There is a drop of water on the cap in the picture but I had just replaced the cap and did not wipe it off before I took the picture.
  • My first TT was a Dutchmen Sport and it had a plastic plug. That was more than 10 years ago now. I put one of these in the plug and didn't even have to unscrew it, or a cap. It worked great.
    Now that my water heater has an anode rod, this idea will not work.
  • downtheroad wrote:
    Good idea...and it sounds like you have tested it over time.
    Somehow, somewhere I thought I read that a metal plug would cause electrolysis/rust issues with the tank...(maybe not???)
    Have you ever replace your pop off valve? I bet it's brass.
  • robsouth wrote:
    Me too. Advised to use only plastic plug to avoid ruining the tank. HMMMM
    As I stated I used mine for 9 years on my TT and now on my 4th year with the MH and no problems. To each his own, whatever you are comfortable with.
  • Good idea...and it sounds like you have tested it over time.
  • What a great idea, those plastic plugs/caps are miserable! Looks like a spring project for me.
  • Going to pick one up now! On another twist I use the same on with a bushing reducer and a 1/4" air chuck and use it to blow out my camper water lines so pick up a couple!
  • :h Why haven't I thought of that. I have been using a brass plug for about 8 years. I like your idea better. Thanks
  • Good idea! Over the years I've replaced several plastic fittings with brass ones in various RVs but hadn't really thought of that.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,368 PostsLatest Activity: May 03, 2025
