Whaase's avatar
Whaase
Time for a new countertop
Well, seeing as I do countertops for a living, I should be doing our new motorhome lol here's what I'm working with.
I guess i should do all of the laminate :)
Table too
Small top between the chairs
Sink and stove taken out
Time to convert the poly-b to pex and install some ball valves w/braided lines.
Time for the old pink tops to come off!
New valves and lines on
Old top off. I'll use this as a template for the new one
L-brackets on and waiting for the new tops.
more to come
Walter
Moderator edit to re-size pictures to forum limit of 640px maximum width.
  • Always replace. Laminate is non porus, so the glue has nothing to soak into.
    Not saying you can't, in just wouldn't do it :) especially if the old laminate started to let go
    Walter
  • Just the window crank :)
    Cutting out all the pieces
    I'll use a copy bit and the old tops as a template
    Putting on the edges
    Rolling out the glue
    A few pieces done
    New taps from a customer
    And installed
    Walter
  • I'm anxious to see the finished product, too!!!!
    Alfred622 --- that's the knob for opening the louvered window.....
  • Looking for Part 2 also! Say, is that an inside camera you have located in the window over the sink? Looks like the blind is cut out for it. Very curious as to how that is used.
    Please post - I think I can learn a lot from your experiences!!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,397 PostsLatest Activity: Dec 04, 2025
