GCasta
Jun 16, 2015Explorer
BurbMan wrote:
Note to OP< be sure you have a brake controller that supports electric over hydraulic, some years of the factory Ford/GM/Ram controllers cannot.
And FYI, the newer Dodge Rams do not work with EOH at leat with Titan controller. I discussed this with Titan and they are aware of it. Dodge must have changed something in the latest models. The Titan rep said he even got calls from Dodge trying to figure out what was wrong. Problem was solved by just using an old brake magne in wiring connections. This can be done on any of the trucks to make EOH work or you can get the module for the actuator you use
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,420 PostsLatest Activity: Sep 22, 2026
