westend
Jun 16, 2014Explorer
I'd opt for conduit. I used flexible non-metallic for brake wiring and it's OK but if I was doing it again, I'd use PVC. I have one underside battery bank run through 1 1/2 ABS but that is overkill for your run. I have two #1 AWG cables, the battery temp wire, and two #14 THHN in the ABS pipe. Liquatite is probably the best conduit, the stuff is darn near indestructible.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
