profdant139
Nov 26, 2015Explorer III
Someone asked about whether you can add an extra step and how tricky it is. Although I haven't actually done that modification to my new Glow Steps, it looks like the job should not be too hard. All of the steps are secured to the "scissor" hardware with fairly ordinary quarter inch bolts, with hex heads requiring a seven-sixteenths wrench. So it should not be difficult to unbolt one of the steps, insert a new step, and then reattach the bolts.
The only caution is this: make sure the bolts are properly torqued. If they are too loose, then the whole set of steps will deploy too fast, with a hard impact. (I know this because the other day, I tried loosening all of those bolts just a little as an experiment, to see if the steps would deploy faster. They sure did, and that's not a good thing. Don't do what I did.)
When the bolts are properly torqued, the whole assembly deploys smoothly but not catastrophically.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
