4x4van
Jul 25, 2019Explorer III
OK, so I finally got this thing hooked up. I initially got the T fitting for the trans line, but I didn't have enough room to cut the line without disconnecting it from the tranny, and I decided against that (not wanting to introduce any possible leaks, either at the cut or the trans). Instead, I had my nephew (a machinist) fabricate a block (similar to one I saw on another website) out of aluminum that simply clamps tightly over the line, relying on metal-to-metal heat transfer.
https://lh3.googleusercontent.com/-nshrDe5puyPt4sh-GS8dx2d--rOnEdlQNAMGyWJh2Z4GaZWSbHPwHcZijQPeyBOIct_STTpbzhCCFD64pT1tWxbsIU6ahktFzU6LIujDUF5sMIUm8kmNMVCwA98kr1nRAV9SwWCV5QXWFaQkeBls5SooqTWi2cUUoqut3ofzYwWGJqzvepvXRQBErvukF2BwcsnQzQ4q6wet21vQABjIah-a4CIqsv-j0s43yaJQJ5xnwrvrXuj98p-a_X-owBAP_uPU3wqOT9LkL2clDkiWa5TPzVD7I9SgO2cl-R8RH56REHGgXkZTl3ebRxhwFS0i0h6H7kTkEBoBDQYc35RAO1pX5CezdcfvZ9EEMTPz3VfDsR0Lcn5gajgqJpFjrsVHccny2bJT0zflHNJERn6740otMAa0IkFk8zVg45RR1k9rK70fK-HCeBo5J5eNOM-oncFyk1dE9NMgTY7xyntWoVmBL7yucNpl_rD4D8YpWw4C2CmZJ92fgxH8j05QRSJogRPDJpuk_jR29jfhzRdcibFT_wDSZ8wd-SViZSfFR23RKXVD6rtwhA43h7MuAGCL0c-fni5maPZfq4Vj5CQfXKrhgndKbFHgUICvPYqKuvr351BlrlvTvrhOR-NPK06P43MRhkZdAiwsmKcCUwgq-kXdhz-FIU=w674-h898-no
It fits tightly onto the steel line (from the trans to the cooler), and I filled the hole for the sending unit with dielectric grease to help with heat transfer:
https://lh3.googleusercontent.com/aztdsoCGTTucoZPIKUPkzqkRBsVjTFlrwWdlj0JI2OW_wjggD9SVterwWH7xgq5ucisvTp55uRICfX6y0AA3DmnDdlm8NsZNAER8SD6Pade37JXHNy0B8P611p8O-DPaFhcAj7IXsbL8q8FtjDy637ydubJHgEhowTjx4pmdkzzCbOCLRV6ciWASG7qjYPZ-pZgYu5Z5i5GsTi0vuTRhklU0Be9YqG1xxEc8jhLAUHJQSG6QXnI2O1g-5uLvdhggyjOT_cSyELMOdnlaRPeya8hnbPSx4_f20Upd2GIHlb5hyaYHC1KOra1R2gaV2K_j2GeX2sFCHzyflNjLjwqKLgEkyWY7wWWxWePyWvm4BWoEIHtdjj-BdK6EbcLlSmovfB79v9uZ3WdOSySOGld_OrYnue8Kxe9rGnNWpbcUIqfjsFBxBeXpkQu6O2OzBsJPR0AqL-Ul4DPzAoiyjmdKRWQ8hFtXiQjM6Bca6ZQIebw3NyhzYlC9ZO3UTb3mxpuhP8_hHgt5nR5fusiOEEuAfUN8kZpYU8YYlLe_RRWZrlOlAWlNCcfp0MV3VsE9-TNePdVI0cueAYP3W-4rNTgLyp7NPM462c2pmcv6RTmV6LUNgMfQzJJBnlb2y6shgXs5GMnnPPMLXybJQhFYhckCshtixPwpQdU=w674-h898-no
Added some flexible wire loom to protect the wiring near the engine/trans, and finally, I wrapped it with insulation to reduce any heat loss from wind:
https://lh3.googleusercontent.com/7D0rTP6zj1gQXq7OIoyn1Fo6hNkRYSLROqbileBckZpGyprCVQrzETTOqjFGiMhX4aLXAGgzxpyTvlTVnIech3iG-qGkSgToV_T1oNx0abYC-jO6-KL6jjJP2EVqRMfM6VywPhF11ma28uzt_5_2fVOprnLC0Wp1D265s_EO16f-07N4pooA0z32DOTAB8Xh1iUKemP3Yk0GGjhAkS_Ayi7xUWezxA3XlrKUnGi4KDTZgJ9tLrq9rJsRvJkFZ3ECzpmRP9xw5Ec5idC4iZ38WnzDe4Vul-oSA9bYYD8dmzmYl1x7aWj-S7Bn0VSPMnZPjoj2LEddHTdfd8mAHO5_UUCyDMu9OxPc5NXpIG0NdWK6dUV4WaMU-NGX0TcX3kVjNrJUPjRoLJ0gAVWQTytc_RfiOcCYkNdBr9E20WpNBeUNA1zWqxDSEh6v6h5hhr_MiFsY_tLy0B2cvm5TP5LuwB8V7WVi5Tb9KgB_12wfoYsh8GSy7Rv8gRFxU84W8ph_UHFkNo_Q8-0pyRqVM82gs_FgByBZ0Yz1sDYJQ5ltE0t1jHQuWJJ8sXp_yEtRMBzxcb4wie3MJdS4MAGHtXbLV3O_sCHDPID5K8l3w1Fw0yDm5N9H9EH-Bxl3SwVsevuC2m6MB07KJUqwBAeHpSNrryK7_Cz52C8=w674-h898-no
https://lh3.googleusercontent.com/o-Pp4q1hISAMoqE51LM8aybgumeIPmtOi_OF_OXFXsnQu-7Nu8poOu8zot0VrAyYniGHQ_ogQIvDsHD26rrX-WpHzmfKUQPMeRZPlhxUVDYTrorz-fNc0zYXHBWSypmBLevQGjBExuABpncGqsB37JnC5WSsqNhCI-ShrvHdHPKk0NyP4UAHMBvEfZDrAy49rQ5JhmdhgWDAxjIbqvxSljnC9d0m5g5kRNXXfM8xBZ17WZ1QNTKeFSTKssPUZniYtXHh8GxtOG_blG-UxrblH1-5zP4rA_5xqXKzntChMUuTIRNNDqT0a9cef1TaVAwvgOHYK5cWkTHRtXwQe8otPdZBNsSWy86dgwUSjXeECaKdaeq2toGgMqHVOIJXKcAfKsTcMQUtm4IuDUNwRTd3qFsPiQ7o_fJbEda1879duM6VNzbzRYL5Md-D2W0au__m9X7QZgIE4lKPH1CPzhuyJcGPlnAbkLGfvUs7Bpxs_ik0j85aCnf7t3CsIjKR_gWfmv7HA-JSqD56YTJHvCeYpn-8TU4FK_CqJ2EVB95QXch8EHyEP-px0fbVh1F3_CrDUJ8EH0jeJw3XTasoR-Vkru2nlx9j7vfc9NMCq0baX6GJZxi-Wc8uHADGZVPRNjZ2kKlbNd-e848L9lc5DD2mHEoRm8F9Gj8=w674-h898-no
So far, in testing, the gauge reads about 5-10 degrees less than the temperature of the steel line itself (per an infared temp gun). I'll monitor/check it during the next few trips to satisfy myself that the difference is consistent. :C
Edit: Hmmm...the pics have been removed from my post for some reason. Guess I'll try links instead.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
