wvcampers
Jun 05, 2019Explorer
I cut the bottom off of the entry door and screen door after installing the Morryde steps on our 2008 Cardinal and a 2011 Jayco that belongs to a friend.You will find that screen door is simple. If you remove the screen the bottom will pull right off. You can then cut the door down and reinstall the bottom. The exterior door is not much harder, The bottom is screwed or rivited on. after removing it you will likely have to use a jig saw to cut the frame while the inside skin, usually vinyl, can be cut with sheet metal cutters. The outside skin is fiberglass and is easiest cut with the jig saw and a fine tooth metal cutting blade.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
