Troubleshoot fridge problem...
- Jan 10, 2024
Well the solution wasn't obvious at all.
I had to go back to my notes from a couple years ago to get some ideas.
When I got back the cooling unit then, installed everything and turned it on,
it didn't work then either.
I was having problems connecting the control rods at the bottom of the fridge,
so only installed the ones I needed: thermostat control and gas/off/electric.
For some reason the far switch was set to gas or off two years ago and that's why
the fridge didn't turn on. I only use electric.
So I focused on the controls again. For some reason this time I thought the far switch
was the thermostat. I turned it to a position I thought would be a good temperature.
Little did I know I had turned the fridge Off again!
After I got that straightened out, the fridge still didn't work!
I was running out of ideas now. A last ditch attempt. I turned the fridge upside down and then
back upright. It finally worked! 🙂
