navegator
Oct 17, 2014Explorer
You might be able to cover the rails with a sheet of plastic attached to the frame and rails so that the table does not pick up to much dirt and grease from the road, maybe with a side sliding door at the front, when you need to clean the compartment tilt the TT a little and hose down the compartment.
Good idea, I can not use it the only area available to me is under the catalitic and that will mwlt my table, I am shure some others will benefit from this, thanks.
navegator
navegator
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,406 PostsLatest Activity: Apr 28, 2026
