profdant139's avatar
profdant139
Explorer II
Oct 22, 2013
Update: flap in the foam around the water heater?
(Edit: SEE OCT 23 POST BELOW FOR SEMI-AMUSING UPDATE)
My trailer is so small (this sounds like the start of a joke, but it is not) that the water heater, by itself, almost puts out enough heat to warm the interior.
So this gives me an idea -- the water heater, which is below one of the dinette seats, is covered in a styrofoam jacket. Ordinarily, that foam is very useful -- it means that we use less propane to keep the water hot, plus it keeps the water heater from overheating the interior of the trailer in warm weather.
But if I could cut a removable flap or opening in the foam, I could get more interior heat from the water heater. It would be a "redneck heat exchanger." I would replace the flap when I no longer needed the extra heat. (At night, for example, we don't really care how cold the interior gets -- we just pile on the blankets!)
So that is my question -- is this idea feasible? Is there some hidden danger that I am missing?
Thanks in advance for your advice!
  • JiminDenver wrote:
    West
    When I first started looking I saw dual purpose panels with a wet side under the PV side. It's what gave me the idea for a coil of hose under the panel you have now. I don't think it'll add too much weight.
    Jim, the hose thing might work, I'll test it out in the next day or so.
    Since I have a diversion load output on my solar controller and the batteries are completely charged, I'm still thinking of how I can use that potential power. That potential could be 180 watts for 4 hours/day and less during the shoulder hours. If I was going to heat water with that diversion the formula is Kw= gals. x temperature rise (f)/ 375 x heatup time. On a perfect day, I'd probably be able to heat my 30 gal. fresh water tank by 10f rise. That doesn't sound like much but if the water in the tank started at ambient, that would be a lot of stored heat to augment the propane heater. Also, that heat is free, basically, just using the yet unused diversion load available.
    Lots of ways to get feline fur. Hitech was investigating using his excess solar to run computers and trade processing time for $$. Not too bad an idea but the payback for the capitol expense was about nine months, in the best scenario.
  • profdant139 wrote:
    UPDATE
    So, I am getting ready to slice into the foam -- I was all set to create a velcro hinge for my foam flap, to drill into the cabinets for vent holes, yada yada yada -- and I decide (for reasons of diplomacy and domestic tranquility) to check with DW. I drag her outside to the trailer to explain the whole thing.
    She nods and says (politely), "Good idea! But how is this so different from a hot water bottle? I could boil water on the stove, fill the bottle, and put it on my lap, under my lap blanket, while we are eating dinner or reading." (That's how cold it gets when we boondock -- we often use lap blankets and wear warm ski hats while we are inside.)
    I sputtered a little, disappointed that I was not going to get to do yet another "mod." But she had a point -- yes, it is a little more trouble to boil the water and fill the bottle. And it might waste a couple of quarts of water per night. But it means that the water heater will not have to cycle on and off, I don't have to cut the insulation, I don't have to drill any holes, and the heat is right where she wants it -- under the blanket -- rather than indirectly warming the interior of the trailer.
    Darn.
    If you are going to use "water heater" heat to warm with, why take the time to boil water? Just use the hot water out of the faucet. Of course, if you are boiling water for dinner, you have it available anyway.
  • We could use hot tap water, but boiling water is much hotter - we will wrap the hot water bottle in a towel and it will stay hotter longer.
  • Wouldn't think the tank temp would exceed 140 - 160 deg F, not likely any fire danger it seems to me. After all, how hot is your water?
  • I am sure the tank temp is not over 150. But the real issue is whether I want to mess with the insulation, when DW simply wants a hot water bottle in her lap.
    Which, coincidentally, is the solution we've adopted! ;)
  • With the OP stating his new, scientific, and novel solution to the problem, it is time to put this thread to bed after three pages of replies. Than you everyone for your participation.
    Barney
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,351 PostsLatest Activity: Jan 18, 2025
