- wingnut60ExplorerBased on my experience with a FloJet, it will handle the rise/distance. Use plenty of extra water if you have a source available.
Joe - SoundGuyExplorer
bluefever02 wrote:
I'd say it's between 5-10 feet uphill.
This British ad for the FloJet Waste Macerator indicates maximum head is 6 metres, or ~ 19.5' so as I said earlier you'd be fine pumping up your "slight" incline of 5' to 10' using 75' of 3/4" discharge hose. - AZDesertRatExplorerThe FloJet chops the solids into smaller pieces but there are still solids that will settle out. Run it into a cup or bowl and you sill see.
And "slight incline" doesn't mean a hill of beans. Is slight a 1% incline, 2% ? Without knowing the height difference over that 75 feet you can't say whether it will work or not. How is that for "clear"? And I also own and use a FloJet. - SoundGuyExplorer
christopherglenn wrote:
don't go to large on the hose, the larger you go, the lower the velocity of the fluids, and solids will start dropping out. Get enough and even though the pump is on, you will get a clog.
Solids? What solids? :h The FloJet Waste Macerator does just that, macerates solids so there are none, just "water". I've been using my FloJet for 9 yrs now, 50 foot 3/4" hose, no issues whatsoever, wouldn't ever service my tanks any other way. After a few minutes of flushing this is what comes out of my black water tank -
- christopherglenExplorerdon't go to large on the hose, the larger you go, the lower the velocity of the fluids, and solids will start dropping out. Get enough and even though the pump is on, you will get a clog.
- wanderingbobExplorer IIIt will do it , within reason the larger the hose the easier , in otherr words do not use a 1/2 inch hose .
- bluefever02ExplorerI'd say it's between 5-10 feet uphill.
- SoundGuyExplorer
AZDesertRat wrote:
You need to know the elevation difference between the RV and the final dumping point. The 75 feet horizontal is not the issue but the height may be. Most macerator or chopper type pumps capable of pumping solids or waste do not handle head well.
The OP already said in his first post - "uphill 75 feet at a slight incline" ... how much clearer can that be? A FloJet Waste Macerator will handle this task just fine. - AZDesertRatExplorerYou need to know the elevation difference between the RV and the final dumping point. The 75 feet horizontal is not the issue but the height may be. Most macerator or chopper type pumps capable of pumping solids or waste do not handle head well.
- rrbowmanExplorer
Golden_HVAC wrote:
75 feet of rise is about 40 PSI. Take into account some friction loss for the pipe length, and you are at a much higher pressure.
If it is just 75' of hose, and say 15 - 20 feet of rise, then that can be done with any RV water pump. How much flow are you looking for?
If you only need about 5 gallons per minute, then the VSP pump that is 5.7 GMP and 12 or 24 volt input can work well. That would be a total of around 300 gallons per hour, so it is a significant amount of water.
You can find that pump at CampingWorld.com and the standard Sur flow is rated around 2.5 GPM. Probably only around 2 GPM at 30 PSI - about what will be required for 75' of garden hose going up 15 - 20 feet in elevation.
Good luck,
Fred.
I don't believe he said 75' rise, he stated 75' with a slight incline.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,421 PostsLatest Activity: Sep 24, 2026
