bluefever02's avatar
bluefever02
Uphill tank system
I've been looking on camping world and other places. Can anyone suggest a good system to pump uphill 75 feet at a slight incline.
  • I have almost exactly that same configuration. Flojet Macerator works for me.
    I gave up on lining up at campground dump stations years ago and use the aforementioned FloJet Waste Macerator Pump to off load both grey & macerated black water here at the house and although my run is 50' and generally in a downhill direction I'd have no hesitation using it to pump 75' with the hose running in a slight uphill direction. For pumping only grey water it's a bit overkill to use a macerator but doing so would allow you to also off load the contents of your black water tank.
    But i've seen some people online saying it can handle over 100 feet uphill.
    I cannot imagine any situation where somebody would encounter a 100' rise to dump their waste water. I doubt any macerater could manage that.
    Bruce
  • If need be couldn't I run a fresh water pump closer to the drain to help the macerator?
  • I have a portable FloJet Macerator that I use mainly when visiting sister ion FL.
    Clean out is almost 100' away with a 2' rise.
    I use 3/4" garden hoses and pump black tank, grey & galley.......120 gallons
    Check various on-line for best pricing
    PPL
    Adventure RV
    Dyersonline
  • I saw a thetford system on camping world that said it could handle 21 feet. But i've seen some people online saying it can handle over 100 feet uphill.
  • I just noticed that I didn't put in that im looking for a system to pump waste, mostly grey water uphill.
  • 75 feet of rise is about 40 PSI. Take into account some friction loss for the pipe length, and you are at a much higher pressure.
    If it is just 75' of hose, and say 15 - 20 feet of rise, then that can be done with any RV water pump. How much flow are you looking for?
    If you only need about 5 gallons per minute, then the VSP pump that is 5.7 GMP and 12 or 24 volt input can work well. That would be a total of around 300 gallons per hour, so it is a significant amount of water.
    You can find that pump at CampingWorld.com and the standard Sur flow is rated around 2.5 GPM. Probably only around 2 GPM at 30 PSI - about what will be required for 75' of garden hose going up 15 - 20 feet in elevation.
    Good luck,
    Fred.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
