Almot
Sep 03, 2014Explorer III
scottyboy28422 wrote:
can we use a regular 110V fridge in our RV for use a campgrounds w
electricity. The small dorm, home type ones. Walmart has some for under $200. The reason Im asking is because of the jolting down the road and also unplugging the fridge each time we leave a campground.
Yes, you can. Inside your trailer you can install anything you want.
Outside, as a portable - don't know. Unless you have a really big company in your trailer, for a short stay a standard 6 cu.ft propane fridge is roomy enough. I personally wouldn't want to lift and move around even a small 110V fridge, even when it's empty.
Walmart has small fridges much cheaper than $200. Though it depends what you consider a "small".
One thing I don't understand is how unplugging it for travel is the benefit of 110V fridge. Propane fridge you don't have to unplug - its 12V circuit will work just fine through the 7-pin connector to truck. There are debates sometimes as to whether it's safe to drive with propane fridge running, this is a separate issue. In any event, 110V fridge you HAVE to unplug when leaving the camp.
As mentioned, a very small 110V fridge can be run off a single solar panel ~200W. But it has to be very small, a few cu.ft. Cheap mid-size fridges from Walmart, say, 10cf and larger are not the most efficient, and inverter adds another 10%-15% loss. Some of them are too wide, designed for home kitchen, not trailer closet.
I'm not so sure that many new RV's come with 110V fridges, or that this is a good idea for everyone. Big motorhomes with a monstrous alternator and on-board generator - probably so. A typical 30 ft trailer or 5-er - I doubt. Unless you are always on camps with electrical hookups, a 10cf or 15cf 110V fridge will require an hour of daily generator run, - this is for the fridge alone, not counting your other needs. And a decent inverter with substantial battery bank. Because you don't normally run the fridge off generator - you run fridge all day and all night from the battery, and then need to recharge the battery, and this involves losses too.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jan 18, 2025
