ItsyRV
Mar 06, 2020Explorer
That thickness has very little structural support and it's always recommended to double up and run the second sheet perpendicular to each other. Or use Wacky Wood 3/8 with a 1/8 topper.
(Double check your weights as neither WackyWood or the bending birch plywood's weight that much per 4 X 8 sheet.)
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
