Econotemp
Mar 16, 2020Explorer
Well i think I’m stuck with what i have the 1/8” wiggle wood, now i will probably add another layer perpendicular, think ill go with 3/8” acx. The wight i put earlier was definitely incorrect it only weighs 20-30 lbs tops sorry lol, the advantage of using the wiggle wood is the curve of the roof can be covered without warping and b4 asked ill put 3/8’ acx first, wiggle wood covering.
On extra question this trailer is a gift from sis I don’t plan on having longer than 2 years than i will upgrade. What type of “coating” should i use? And should i bother with building curbs for A/C and vents?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
