frankwp
Nov 20, 2014Explorer
Not to mention the moisture issue. The furnace exhaust contains a lot of water. If you dump that into the under belly it'll just condense on any cool surface which will lead to rot & corrosion. So even if the floor is perfectly sealed (which it definitely is not) it's still a real bad idea.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
