I_am_still_wayn
Jul 06, 2013Explorer
Putting that much weight on the back of a travel trailer is a bad idea. The trailer frame is not designed for that weight and could cause structural problems. That much weight on the back lightens the tongue weight which could cause stability problems while towing. The machine itself is not designed to be out in the weather and you can expect for circuit boards and other electrical components to fail quickly. You could also expect rust to form in and around the machine ultimately rendering it unusable. Overall, this is a bad idea.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
