vlopddap's avatar
vlopddap
Wall-mount TV in small travel trailer ?
Hi, I'm just wondering how do you wall-mount your TV in a small travel trailer? I have no reinforced wall surface to install a swivel wall-mount bracket for my 19 inch LED TV. I'm wondering if I can put a reinforcement wood piece over the wall, glue the wood piece with industrial adhesive maybe, then screw the wall-mount bracket through the wood piece and into the wall surface? Also I install the wall-mount bracket over a countertop surface, maybe I can screw the bottom of wood piece onto the countertop with metal "L" brackets too?
My TV is very lightweight since it's a 19 inch LED (under 10 pounds) and the wall-mount bracket itself is pretty light too (2-3 pounds) since it's all aluminium.
Any other suggestions? Pictures of your own setup would be appreciated :B
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,411 PostsLatest Activity: Jul 03, 2026
