coolbreeze01
Mar 25, 2015Explorer
dkreuzen wrote:
I ended up getting a set of the NEW Carlisle RADIAL TRAIL RH tires (ST225/75R15 E) when they first came out. For the last 15yrs I averaged about 2yr / 6000 mi on a set of tires before one separated. So far, the last 3 years / 9,000mi the Carlisle tires look the same as the day they were new.
If you have to go with 15" tires, the above seems like a good choice because they will be readily available. Maxxis aren't carried at a lot of tire dealers. I had to order them when I bought a set.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,408 PostsLatest Activity: May 09, 2026
