JaxDad
Jul 28, 2015Explorer III
SoundGuy wrote:
I'd prefer using some sort of water resistant enclosure designed specifically for the purpose but have never have come across anything suitable, even plastic tool boxes have always been too big. Recently though I discovered an inexpensive plastic shot shell box manufactured by Plano Molding that is readily available just about anywhere, is just the right size, and which has a hinged lid with a rubber O-ring that is secured tightly with a brass bail latch. Modification involved only cutting in the required cable entry & exit holes with a sharp knife and adding a couple of rubber grommets for a tight seal ... pics are below for anyone that may be interested.
I went the cheapo route, I got a plastic pail from the dollar store and put a small eye bolt through the center of the bottom, eye to the inside. A very short bungee cord suspends the connection up inside the inverted pail and well clear of the ground. When I'm packing up, the cord gets coiled inside the pail till next time. Double duty.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
