JKJavelin wrote:
FWIW, I did a little testing with our Oxygenics showerhead a couple years ago and found that keeping the flow as low as possible but still getting a spray effect, it would consume .6 gallons per minute.
Now, as far as toilets go, I read about people saying "use plenty of water " for the black tank, as well as many saying that they can go 2 weeks before dumping the black tank. How much should you put in the toilet between flushes?? We put about a quart of water in (I've measured it!). Too much? Not enough? With a 41 gallon tank, we can go a week max before the dreaded burp.
JK
You are in a whole different category from some of us who are concerned about saving a few cups of water. For example I am trying to get by for a week or so with a 30 gallon FW tank. It seems that you use more than that just flushing your toilet.
My RV is more boondocking oriented. It has a built in cassette toilet. The water tank for flushing is a separate 6 gallon tank. Flushing is very efficient and only requires a very small amount of water from a high velocity jet. Flushing uses maybe 2 gallons a week.
Even with a built in toilet you should not need a lot of water to keep the system working. Even a very minimal amount of flush water should work. Chemicals and sloshing during travel should avoid any build up and most RVs also allow you to use GW when dumping to break up any remaining sediment.
