rjniles's avatar
rjniles
Water tank filling mod
A modification I made to more easily fill my fresh water tank. I installed a 1/2" threaded 3 way ball valve in the area of my water pump. I connected the input to the valve to the outside hose connection. One of the output ports I connected back to the water pump, the other output port I connected to the old breather hose to the fresh water tank. I cut a hole in the bulkhead wall of my front storage box to access the valve handle. The old filler hose now acts as the breather hose and I can still fill the tank with that hose.
With a hose connected to the RV, I reach the valve thru the storage box and turn to the fill position. It will fill my tank in 4-5 minutes (will depend on water pressure).
I used PEX pipe with SS cinch rings for the connections(I own the tools and connectors). You could also SS 1'2" FPT faucet connectors.
Trying to figure out how to post a picture.
  • Lately I've been seeing quite a few posts about mods & different ways to fill the fresh water tanks, some, Like this one seem to be a lot of work, makes me wonder, do I have the only MH with a gravity fill port, remove the cap, stick the hose in the hole, turn the water on?
    I have a friend with what appears to be 2 city water connections, but one of them is to fill the tank.
    I thought all RV's came with a way to fill the tank. :h
  • I’m nervous about filling fresh water quickly and look forward to your pictures.
    Follow the instructions In This Link to fully understand how it is done,very easy to use.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 13, 2026
