Sparky502's avatar
Sparky502
Water transfer pump
I am looking for some feed back on my idea for filling the fresh water tank. Sometimes when we are boon docking we need to top up the fresh water tank and we haul it in water cooler jugs. To speed up the process I was thinking of purchasing a cheap fresh water pump and wiring clips to attach to the RV battery for a 12 volt power source. Hook up FW hoses to the inlet and run another to the FW tank and pump away. It seems like a great idea for me but wanted to see what others.
  • We use this inexpensive pump.
    http://www.heartlandamerica.com/browse/item.asp?product=liquid-transfer-pump&PIN=48043&BC=S&DL=SEH3
  • That is genius and the reason why I joined this forum. My 5th wheel doesn't have that option but I planned on putting a three way valve so it would be a little more convenient to winterize it. All i need to do is carry a short hose to throw in the water jug. Thanks for the idea, that is a great idea.
  • Dunno what you have so I'll toss this one out from a thread a long time ago.
    If you have an anti-freeze position where the pump draws from the 1gal containers, drop that siphon into the potable water tank.
    I'm sure there are other ways, but next I go to the outside shower with a hose jumper built to go from the outside shower faucet and into the street fresh tank fill.
    Start pump and open the faucet. Takes me around 2 mins to drain a 7gal portable potable jug.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,409 PostsLatest Activity: May 28, 2026
