jrichard's avatar
jrichard
Weber Q conversion to run off house tanks
There have been a number of threads about converting BBQs to run off the RV propane tanks. Most questions center around which fittings to buy, where to buy, and how to remove the BBQ regulator.
I'm starting a new thread because I just purchased the fittings I need from Calore Equipment and wanted to share some information. (Their site: www.caloreequipment.com )
First, the customer service has been excellent. I've had a number of questions and they've been answered quickly and accurately. Not only that, when I corresponded with a senior member of the management team about obtaining a 1/8" fitting for the Weber Q, he immediately recognized that folks with that BBQ could use a 1/8" fitting and put one into production.
Second, they have the fittings you need. To save people time, I'll list what I bought with part numbers:
1. #401153 1/8" MNPT - 250 Male quick disconnect (for the Weber Q...this is the fitting newly in production...so you no longer have to step down from a 1/4" fitting!)
2. #104052 Female quick disconnect and ball valve assembly (this is to put on the RV. For safety, I'd recommend using a valve...either integrated as I did or get a separate valve)
3. #100395-120 10' RV dual quick disconnect hose (to connect RV to BBQ)
4. #302004 Dust cap plug (to cover the fitting on the BBQ when not in use)
5. #302005 Dust cap socket (to cover the fitting on the RV when not in use...turns out you don't need this as part 104052 comes with a dust cap)
If you're measuring fittings, this is a great resource:
http://www.fairburyfastener.com/xdims_pipe_threads.htm
I haven't made this modification yet. I still need to go to my trailer and figure out which fittings I need to attach the female QD/valve assembly to the existing plumbing. Those fittings should be available locally and will vary depending on your RV (...mine has a hard gas line running down the length of the trailer to the water heater in the rear...I'm going to tap into that line where it branches off to feed the water heater, stove, or heater).
In terms of cost, with shipping I spent $95 and will likely spend another $5-10. I can buy a lot of little propane bottles for that amount of money. For me, it's about the convenience of not having to stock up on propane. I figure if my trailer manufacturer offered a "BBQ quick disconnect fitting with 10' hose" for $100, I would have checked that box without thinking about it.
The person who helped me at Calore asked me to send photos of the installation so they can use them to help others making this modification. I'll also post them here once this project is finished.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,351 PostsLatest Activity: Jan 18, 2025
