westend
May 10, 2014Explorer
You could drill a small diameter hole where you wish to locate a mount. That should tell you if they are metal or wood. My rafters were wood but I used #12 sheet metal screws to attach the mounts so I would have been using the same fasteners in either case.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
