Pepperoni
May 04, 2016Explorer
janegowest wrote:
What are you folks using to create a ledge or shelf? I have to have water by my bed as well as eye drops, sleep-aids, etc., but the unit that we are considering has no ledges.
Would love to see some of your mods for this type of situation!
Thanks for your help in advance!
You could build a simple metal holder to keep your favorite mug or jug close at hand. Use a suitable metal (or plastic) sheet. It will attach under your mattress (screwed to the wood beneath the mattress.
The only work to be done is to bend the work stock around the lip of the bed and to make a hole of a suitable size to fit your mug/jug.
The piece is then screwed down under the mattress, and reaches away from the bed to hold your water mug.
------/______
You can size your holder to fit your favorite medicines, either using more holes, or fit sticky velcro to your meds, etc
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: May 25, 2022
