hammer21661's avatar
hammer21661
Where not to mount your sewer hose holder
I have the rig in sig and mounted two of the 5"or 5.25" fence posts to the level up piston mounting holes on the bottom with a piece of aluminum angle. Problem The heat from the generator will melt it. I wrapped the exhaust pipe with wrap but the heat coming down the hole from the engine was starting to distort it after a few minutes. SO I have to move it from front to back. Between the sewer pipes and exhaust I can only go to the rear most set of levelers. Hopefully this may save some time for someone else.
I don't know how to post pictures so, sorry.
  • Old Duck wrote:
    I mounted mine about half way between the landing jacks and in front of the tires where there was room. Close by is the under mounted spare so I figured if I ever high ground and hit it, I've got other problems.
    Grey and black tank pipes in the way there.
  • I mounted mine about half way between the landing jacks and in front of the tires where there was room. Close by is the under mounted spare so I figured if I ever high ground and hit it, I've got other problems.
  • Mounting on the rear will make it much more likely to catch on something and get torn off.
