Dutch_12078
May 14, 2014Explorer III
As said, the reefer vent is a common access point for add-on wires. For temporary use though, a window may be a better option with the small gap covered with masking or duct tape. Also note that the ground plane metal sheet need not be that large. A 12"x12" panel is more than enough. I made my permanent metal roof panel 12"x18" since I was mounting multiple antennas on it, but even that is overkill.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,403 PostsLatest Activity: Apr 09, 2026
