cpaulsen
May 15, 2014Explorer II
Used a metal piece of angle that I mounted to the top of my ladder.....ran the antenna wire thru the slide out. Used some small command hooks inside to hold the cable over to an outlet I installed for powering the Wilson Sleek which holds my JetPack. I can run the slide in and out without even moving the cable and the mag mount antenna(12") stay right on the ladder even moving down the road.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,403 PostsLatest Activity: Apr 09, 2026
