Clay_L
Jun 02, 2014Explorer
My 96 Warrior had an aluminum roof and they use fiberglass now but I think the process is the same.
There are no voids as such.
The roof is laminated in one piece. The thin fiberglass sheet (1/16 inch or so) is bought already laminated to 1/8 inch thick luan. That is layered with Styrofoam 4x8 sheets, then the inside wall covering pre-laminated with luan. They use huge numerical controlled routers to cut paths for wiring and aluminum roof trusses and structure before lamination. A water based contact cement is used as the bonding agent. The whole roof goes through huge rollers to press it all together. Here is a cross section picture of the roof edge,
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
