shutdown wrote:
Well how did you wire in your second ac? my thoughts are either wire it back to the 30 amp panel or run a second, 20amp line out. Since most power b pedestals have 30 and 20 amp connections and I occasionally pop my 30 amp breaker without a second ac I am leaning towards putting out a second line.
Just a thought, you might want to check out your opening where you want the second AC to see if the roof has been factory braced for a second air. If it came from the factory with support for the AC then it is possible that it is already wired. Good Luck and Happy Camping.
