shutdown wrote:
Well how did you wire in your second ac? my thoughts are either wire it back to the 30 amp panel or run a second, 20amp line out. Since most power b pedestals have 30 and 20 amp connections and I occasionally pop my 30 amp breaker without a second ac I am leaning towards putting out a second line.
First, find out why your 30A breaker "POPS"...
It's normal for it pop if you short cycle the A/C, turn it off and the back on quickly during a compressor cycle.
With no ~1000W microwave load 30A should be sufficient provided you have the "kit" installed that prevents both A/C's going into a compressor start cycle simultaneously.
