westend
Apr 20, 2018Explorer
Any insulation that is installed under the floor is going to make comfort increase in a travel trailer. I've done three, so far. Keeping water lines, drains, and tanks from freezing is a tangent from insulating the under belly since you need some sort of heat to keep things from freezing (assuming parked or travel at a low temp). I'd suggest to consider some heat tapes or tank heaters.
FWIW, I have a tank/drain project for my trailer scheduled. I plan to enclose the single waste tank (maybe add a small grey tank) and all the drains right out to the drain exits. I will use 3/4 extruded polystyrene clad with aluminum sheets to enclose the areas. Heat will be supplied by a 60' length of gutter cable and a heat tape toward the outboard ends of the drain plumbing. All of this nonsense is inside a steel frame. The GFCI circuit with switched receptacle is already installed. It will allow me to camp at any temperature and be able to dump waste. A side benefit is that all of this is directly under my bathroom area and should serve to keep that floor warmer.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
