rexlion
Apr 21, 2018Explorer
Icynene is a type of urethane foam, but not dense so it could absorb water. Application of sprayed urethane is a pro job for someone with the proper sprayer and equipment, not really geared toward DIY, but it (the dense variety) is very good insulation.
EPS (edit--oops, should have said xps) will work well too.
I assume you will attach the coroplast with hardware? Those sheets are tough to get glue to adhere... even the specially etched sheets.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
