alex800's avatar
alex800
Yet another thermostat upgrade question
I purchased non-programmable Honeywell thermostat and still confused on how to connect it in my Heartland Wilderness 3150DS.
The model of the new t-stat is RTH5100B.
There are 6 wires in my TT connected to Coleman-Mach analog t-stat. I decided not to install additional switch for Hi/Low fan operation to simplify the installation. I can always add it later as long as I can identify all the wires.
Here are the wires that are coming out of the wall.
Red
Yellow
White
Brown (Connected to Grey)
Green
Blue
I know I need to connect White and Yellow but I’m really confused about the rest of the wires. Some posts saying not to use Blue and Green others are saying not to use Red.
The new –t-stat has the following connections:
Rc
R
Y
Not used
W
G
I would appreciate any help with this mod.
  • Nothing conflicting......
    One is for a Dometic (DuoTherm) and one is for a Coleman-Mach
    Two different A/C Units.......different wiring configuration
  • Looks like we have conflicting diagrams here but I will need to follow Coleman Mach diagram because this is what I'm replacing...
  • alex800 wrote:
    newman fulltimer wrote:
    coleman. honeywell
    red.............red
    blue.............not used
    white,............white
    green,............to high fan
    yellow.............yellow
    if you dont wasnt low speed tape off all other wires
    Assuming Green wire to G connector and tape off Blue and Grey. Did I get it right?
    Correct.......
    Blue (12 neg) is not used and Grey is for low fan speed (would need switch to use Grey & Green)
  • newman fulltimer wrote:
    coleman. honeywell
    red.............red
  • coleman. honeywell
    red.............red
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
